they are owned by the same company and seem to run on the same terrible website but thier stock ranges are quite different and i belive they dispatch from different places.
I too could very often do with the plain bottom part of the NTE5a. They are available through your friendly BT guy, but never found a source elsewhere!
Spark123 - CPC's ADSL filter plate only has filtered IDC's on the rear. I prefer the type with filtered 2'3'4'5 terminals for extension phones, and unfiltered 2'5 to run a pair elsewhere to an RJ11 outlet for the computer.
You can run the 3pair as usuall (or more pairs), and use a pair for the ADSL and 2 pair for the extensions.
In a new build, when you have no idea which socket they want the ADSL, the filtered plates are a good idea. They fit a standard 25mm backbox, and have a filtered outle for the phone, and an unfiltered RJ11. You can put them everywhere instead of normal sockets. This is when I could do with the blank NTE5 plate!
