I've just had a Drayton TA/M4 valve replaced with a Honeywell V4073A........My plumber doesn't do the wiring....
Problem is not only is it a different colour code, the old valve used a relay box which I have to take out.
I've sort of got things working but the hot water is not being turned off by the cylinder stat, nor will the heating run alone(should it?).
HEEELLP!!! Cabby
HEEELLP!!! Cabby
