one light switch stopped working - baffled by wiring!
Hi SUNRAY - yes, the bedroom is also on a dimmer.
I change the dimmer module on the right hand side, but perhaps that's not even the module causing the problem, and it's one of the other two? If relevant, when I connecting 3 wires into the same hole, the bedroom also worked fine!
So it too is a faulty dimmer. I think it may be time to call an electrician if 2 have failed close together.
Agreed. Bit of a coincidence that they've both gone at the same time.
Thanks for all your help & time, much appreciated!
I dont suppose it has coincided with a change of lamps from incandescent to LED?
The problem with having multiple threads running is losing track of what has been written where, I thought this had been ruled out already but I don't see that in a skim read.
