OK, see you all agree the radiators are nice...
But you still don't agree on the solution!
How's a poor rookie to know what to do
So could I ask some straightforward questions?
1. If we do replace the boiler, presumably the pipework between there and the cylinder will need replacing? Does this have to be anything special given the rest of the system?
2. Is it best to put in a new cylinder? If so what would you recommend?
3. Sounds like for our needs you're recommending a Kidd 2 (well that's what Mr Kidd suggested...) or something called a Broag? Are the other boilers you guys recommend (Vaillant? Worcester? etc) also worth considering? I'm asking because if I am going to find an engineer/installer to do it, I may have to go through the boiler manufacturer's recommendations.
4. Mr Kidd also suggested getting someone to 'take out a section of pipe' to check for sludge etc. He suggested flushing the system but I've heard different views about whether this would place too much stress on the joins etc? Would be grateful for a definitive view? On the previous message someone suggested something called a magnaclean or ventiflow or summat...
5. Are you able to recommend a ballpark figure for these bits of work because I have NO IDEA what is should cost and need to know what will be reasonable from a quote...
Not much to ask then!
Thanks by the way: I really appreciate some expert and neutral help with this...
