Hi
Our landlord has recently renovated our flat, including removing the florescent light in the kitchen but neglecting to put the new light he bought as a replacement.
I got tired of cooking by candle light (usually undercooked than over) any how so I tired to put up the new light and oops big spark and no lights in the rest of the house.
Wisely I removed the lighting fuse, it was only when I put it back there was a spark at the fuse box.
so this is what I did,
basically there are two sets of main white cables protruding from the ceiling, from which there are one red(live), one black(neutral) and one yellow/green(earth) wire coming out of both of the cable.
the red wires coming out of both of the white cables are joined together by one of white plastic connectors with little screws in it.
and the yellow/ green ones are joined together by twisting.
the black cables are separate to each other and the naked end of the wire has been insulated with white insulation tape.
so I removed the little white connector from the two red cables and since they were both twisted together I connected them to the new light, to the connector position marked live, I joined the two black cables together and connected them to the new light to the connedctor marked N, and finally I connected the neutral cables together and fixed the new light to the ceiling.
When I put the lighting fuse back in, it made a loud pop and made me jump.
I don't understand what I did wrong,
please can someone advise me, it's the bank holiday weekend, and I'm sure someone can advise me what to do.
Before you ask, I haven't got a voltage meter.
thankyou.
Bob
thankyou.
Bob
