Open system vent pipe horizontal run.
Back again.
After lots of measuring, I find I can fit an alternative F / E tank......
In a much better place.
Before I start cutting / swearing etc.
Do you think this may go some way to improve things.
Thanks All again.
Ian.
Back Again.
I bought the new F / E tank I showed.
I've fitted it carefully above the Cylinder as shown in the 3rd diagram.
STILL, the air won't rise up the expansion pipe.
(I've checked it isn't blocked)
I can hear lumps of air running round the DHW cylinder loop.
It seems happy to turn 90 degrees left rather than bubble up vertically.
I fully understand the system is not plumber correctly but,
before I start with floorboards up to run dedicated fill / expansion pipes,
does anybody think an automatic air vent in the top of the cylinder loop
might solve the problem?
(See diagram 1 where "flow" is written).
Many Thanks.
Ian.
you were told the pipework configuration is wrong, by more than one of us, yet in your own wisdom you fit a new f&e tank albeit in a diferent position. Why am I not surprised it is no better?
Yes, you're all correct.
Pretty much everything I do, I try to do Properly
so I only do it once.
On this occasion, I thought I could just improve a bad installation.
I admit I was trying to save time & money.
I'll just have to bite the bullet.
Carpets & floors up, new pipes from loft to kitchen.
Just to confirm......
Boiler......
Vent......
Feed (from underside & within 100mm)......
Pump......
DHW Actuator......
CH Actuator......
Again......
Thanks for all the advice.
I'll listen better in future.
Off for my tea now......Humble pie I think!
Ian.
