opening a fireplace
23 Sep 2013
Manchester
hi there i am looking for some information regarding opening up my fireplace to fit a log burner.
it currently has a gas fire fitted into the hole the house was built around 1920 and it fully brick i have removed the gas fire and inspected up the chimney i think i can open it up a bit but would need a new lintel im just wondering what size approximatly it would be also the back of the fireplace the brickwork seems bricked up to a certen point then the chimney goes bigger about 3 foot up from the floor should a chimney for a log burner be straight square top to bottom or is it normal to be smaller near the bottom ive heard its called a smoke shelf or something i have a chimney sweep coming round next week. any answers would be very much appreciated.
Hi Azza.
Are you sure you'd need a lintel?
We've just done the same and didn't need one.
When it was opened up we found 2 lintels, a small one and a large one (about 12" above the small one). We remove the small and kept the large.
Cheers
