We had (extra) insulation fitted when we moved in 9 years ago - to make it 10" I think. After a short time, we started to get dripping bedroom ceilings, the condensation was so bad. We had the "technical expert" out eventually from the insulation company who went up there and said we lived in one of those rare properties that probably should not have that amount of insulation - due from memory to the direction the house is built in. He then suggested either taking the insulation out or fitting air bricks to two walls which we had done. This solved the condensation problem in the summer, but of course caused the winter problem of a freezing cold loft. We had frozen pipes (no damage thank goodness as we have a great plumber), then a leaking storage tank which had to be replaced. We've had the "new" tank lagged well, but live in dread of further problems. We've also sought advice from others as well, but no-one has a solution and, as I've said previously, it's so tight up there, you can't move. Perhaps it would be easier to move house!
