There may be something in what you say. I have just come across a report produced for the Energy Saving Trust by an Gastec last September entitled "In-situ monitoring of efficiencies of condensing boilers – TPI control project extension". It is the second phase of a long study in real homes of condensing boilers efficiency.I don't think the cycling approach adopted by the CM927 works well with the modulating approach of the Avanta.
In the summary it says:
It is acknowledged that there could be potential conflicts between the logic of the TPI controller and the in-built logic of a modulating boiler.
I haven't read the whole report - it's 117 pages long - but it seems to concentrate on "efficiency", while I think the main reasoning behind TPI controls is comfort, i.e maintaining a stable temperature.
The only speeds quoted in the manual are the min and max. So is the start up speed set to 22 or is the boiler clever enough to know that 22 is the most appropriate start up speed for your system? It would be interesting to know what other Avanta boilers do.dumbrill said:Except that in the case of the Avanta range they don't. The start up fan speed is set to 22 against a max of 35.
That's because the tech side has been taken over by Heateam.DeltaT2 said:Their iSense stuff is good but oh my gawd their technical guys are clueless.
I recently emailed Remeha for advice about using an iSense with an 18V open-vent boiler. This was because it is shown as an option in their wiring manual for System boilers but not for OV boilers, which I thought very strange as there is no real difference between System and OV.
The reply I got came from someone in Baxi Group Sales and it was obvious that he had just looked at the wiring book and concluded that it was not possible. No explanation as to why it can't be used.
