Opentherm Weather Comp and Intergas HRE 24 OV
Mike, You may consider upgrading to a X-Plan, Intergas support this, enabling dual flow temps, one for DHW and the other for CH. I'm guessing you are already away? A normally open 22mm valve would be required. The wiring changes are less challenging. Typically the cost saving in energy over the longer term will outweigh the capital investment, rapidly given the crazy energy prices lately!!
Very interesting thanks - does appear to be a solution. Only issue is we have 2 heating zones. The second one is for just two rooms with its own controller and isn't used that often. Maybe I could leave that MV as a NC type and leave that zone as non-OT. If that called for demand I guess the boiler would think it was being asked for HW and set temp to max - maybe that's ok as such a small area....
Hmm you could just manually open the spare room valve... quick fix!
I'm an electrician and gas engineer, so more used to manual effort, not for everyone
Your combination of trades is the best possible IMO - will encourage my son to do something like that if he shows interest.
Hmm a new 28mm NO valve would be about £115. Might be easier to fit something like this to reverse the NO/NC signal. Don't think its a safety critical issue as no valves from boiler to header tank and in any case the boiler would just shut down if there was no flow. Could be wrong though....
As a non plumber/heating engineer I might have missed the point, but we've just gone from a quite old condensing boiler with a set flow temp/nest thermostat to an ASHP with weather compensation. It has been running all of October and cost us almost exactly the same as last October (taking into account price fluctuatiions over that period so it was in fact a little cheaper but prices have gone down since then). Looking at the average temp it has been 1 degree colder this Oct, versus last year.
The main benefit we have felt is comfort, without a doubt. Same running costs, for no setback to 15/16 at night or when we are out; no temp drop in the house before the heating kicks in. I came back the other day and for whatever reason the flow temp had shot up to 50- no idea why as it had been coasting on 35-40 all month. Straight away it reminded me of the old boiler without WC. Almost uncomfortably hot with piping hot rads, and then it would all turn off and then it would get just a bit too cold before the heating kicked back in again. A seemingly one off event though and it is back to ticking along at 35.
