I've just managed to check the wiring and I had it right. I have tested for 12v at the bell box and it's there.
I have put 12v across the bell box on the ground and nothing - led's do nothing.
There are five jumpers running horizontally.
The top one is to the right showing - neg
The second is to the left showing - applied
The third led disable - nothing
The fourth is to the left - SAB
The fifth is to the right - ext bat select
Is there anything else I can do before returning the panel?
Hi, I've just checked the wiring and it appears correct.
I have also put 12v across the bell box and still nothing.
Looking at the 5 jumpers they are as below going horizontally down.
- first one is to the right - neg
- the second is to the left - applied
- the third - has nothing
- the fourth is to the left SAB
- the fifth is to the right ext select.
Does it make any difference there is an external sound bomb across the Bell + / -.
The jumper links are ok i think, only the battery one needs to be enabled. If you put 12v across Hold off + - on the siren do you get anything? I'm not a fan of pyronix but I doubt its faulty. Make sure these wires are in as per the diagram i done.
Bottom link needs to be set as internal ( to left ) close lid and open sounder should ring , close it and it will stop and leds will be on
Check the back tamper adjust ,long self tapper through the hole at the side of the micro switch screw in until it touches the wall
