the point is the workman must be given the chance to put it right.
all this without speaking to the workman and giving them a chance to put it right? on a years old alarm system? that did not even sound when the wire was cut?
Letting them know is enough.
Did you not understand that part?
Good for you.
Others need the work done immediately.
And the methods given are tried and accepted.
Your not going to accept anything else, so carry on on your own.
Nothing wrong with a solder joint if done correctly.lee2009 said:the op could however quite easily go with the solder fix if they wanted to, but is quite within there rights to claim for full replacement cable.
I wouldn’t want a carpet fitter fixing the cable! So if a carpet fitter damaged a mains cable you would let them fix it?
The carpet fitted will have to pay an alarm company to fix and test.
Unfortunately this will attract some criticism but I understand you are in a bit of a predicament. If you went wireless (not the ideal option IMHO) would you be installing it yourself or would you have to pay for the installation?decent ones cost around £150 to £250.
