We have recently moved to a farm house and we want to run power to the out buildings. There is already power in 1 or 2 of them, however I looking to put power in the other building as well. The old fuse board needs replacing. I'm also planning on renting out 1 of the buildings and need to put a meter in there so I can charge them the correct amount.
Am I able to use 16mm swa, then go into a 125amp switch, split the cables, 1 for the rented building, the other of my use, and put both into boards. The 1 for my use will be a 80amp 4 way board with 1 mcb 6amp for lights (1.5mm cable), 1 mcb 16amp (2.5mm cable) for sockets on a ring in the building near the board. The other 2 spaces in the board can I use a 16amp(2.5mm cable) for lights (strip lights and pir security lights) and would it be a 32amp(4mm cable) mcb for power as these building are further away. In the building I'm going to be renting, I am planning on using a 40amp 2 way fuse board as this is close to the fuse board, 1 x 6amp (1.5mm cable) for the lights and the other a 16 amp (2.5mm) for the power which will be on a ring.
Can someone please tell me if I'm correct with what I'm planning on doing.
If you need any more information, then please just ask.
Many thanks.
Jimbo
Many thanks.
Jimbo
