How did they work it out? Should be based on value of the building work.
Or get a quote from an approved inspector.
That work is not much more than a garage conversion.
Ask them to justify their costs.
resending proposed plan.
We currently have your proposed floor plan, please provide an existing layout
why are you resending proposed plan when they requested the existing layout.
.Might be easier to just move to a better Local Authority
Above sounds about right, i know its ridiculous what they have asked me to pay, may be chancing the opportunity? Anyway, I am hopeful that some sort of sense would be reinstated.I paid £206 for a planning application then £200 for a Full Plans BUilding Control application for a loft conversion and decent sized extension. Then £570 for all the inspections to go with that. Your costs are ridiculous.
200 plus 570= £770 . £840 not massive amount more at £70 differenceI paid £206 for a planning application then £200 for a Full Plans BUilding Control application for a loft conversion and decent sized extension. Then £570 for all the inspections to go with that.
I was comparing the building control charges, you quotedYes, if you add those numbers up they're similar, but the OP has only submitted a Building Notice, so knock £406 off for the planning permission and Full Plans. Then bear in mind my charges relate to two projects, both of which will involve a lot more inspection than what the OP is proposing and......
- which is £770 surely£200 for a Full Plans BUilding Control application for a loft conversion and decent sized extension. Then £570 for all the inspections to go with that.
why planning is separate from building control, and why knock £200 off for the full plans submission charge comparing building control charges there is £70 difference.so knock £406 off for the planning permission and Full Plans.
