Just to continue the thread drift, it is only the DNO network that is governed by ESQCR, any fixed wiring in buildings etc. has to comply with BS7671
Which is what I have confirmed
You'd use a ring final to supply an outbuilding?running a supply to the existing SWA and a return would mean that you would have a separate ring for the shed thus enabling future modifications.
IMO any supply going outside and sharing a circuit or an RCD with stuff inside should have a DP isolator inside the house, but AFAIK it's not required by the regulations.I thought you had to have a double pole isolator in an external building which is not adjoined to a property?
If you just spurred off then the extension becomes an unfused spur which can only supply one accessory. If you use a fused spur you may fit more accessories all of which together will be limited to 13A max.
Also, DP switching is necessary so when it goes pear shaped you can simply turn it off in the house, if you get a decent enough switched fused spur unit then it will have a double poled switch on it.
Depending on how your electrician decides how to interpret it, you may also end up with another DP isolator in the shed.
If he wants more than one accessory i.e. sockets and fixed lighting then it needs to be a 13A fused spur.
I think this exchange is going to confuse people. All Spark123 is saying is that an unfused spur of a ring final circuit is not allowed to supply more than one accessory, which we all know to be the case. Why are you questioning that?Why?If he wants more than one accessory i.e. sockets and fixed lighting then it needs to be a 13A fused spur.
Kind Regards, John.
