Outdoor decoration extension
25 Jul 2006
Kent
Does anyone know what this connector is and also where I can purchase an extension lead with this type of connector on? i.e a lead with a male and female of this type on.
GALLERY]
It's on an outdoor decoration and is mains voltage (230V).
I think it would be most helpful, if we could see the male connector, but I assume this is not possible, looks like an XLR connector. What voltage is it on?
No, it's not an XLR. Possibly compatible with something from the Bulgin Bucaneer series if you're lucky but quite likely to be proprietary, I've seen similar on various Chinese LED products aimed at the entertainment market.
Chauvet, NeoNeon & Showtec amongst others use them on IP rated ELV LED products. I have an idea that Hozelock may also use them on ELV garden lights & pumps. Might be worth a look on the websites of any of those mentioned.
If you use that cable in wet conditions then ensure there is a RCD in the supply to the cable.
IP44 rating
IP4- Protected against solid objects over 1mm e.g. small tools, thin wire
IP-4 Protection against water sprayed from all directions. Limited ingress permitted
Limited ingress means moisture can get into the connectors, even if mated, and this could present a shock hazard if picked up when the cable is wet and the power still ON
Dan, you're the man! That's perfect, 5 metres will be just right.
Bernard, thanks for the information, yes it will be on it's own RCD.
Thanks everyone for taking the time to reply.
