Ok. I'll get a sparky. And yeah I'll look into a heater too (I was hoping that a solar cover would be enough?)
The cost is starting to mount up though
...from a decent heater. For this you will need a separate supply from the main CU which should only be installed by a qualified electrician.
A heater is a must. As somebody already commented - water below 28 degrees feels drastically unpleasant to the body!
If heat pumps for swimming pools are supposed to be hardwired does that mean that i cannot disconnect them from the supply for winter and put away?
or move the heat pump to another location/house?
Does it also mean that an electrician must connect it and disconnect it every time?
Yes.If heat pumps for swimming pools are supposed to be hardwired does that mean that i cannot disconnect them from the supply for winter and put away?
That would have been the nominal temperature then?Even the not quite so local indoor pool only managed 74˚F, or 26˚C.
Have we all become wimps? When I were a lad the local outdoor swimming pool could go down to 60˚F, or 16˚C. It was cold but I survived. Even the not quite so local indoor pool only managed 74˚F, or 26˚C.
My problem is that I live in rented accommodation so I don't like the idea of it being fixed in any way. And costs are a problem.
£390 for an eco 3 heater, £130 for an upgraded pool pump, 18p per hr running costs (almost £5 day / £600 per season).
So I'm thinking of trying 2 big solar panels - like this:
https://www.amazon.com/Panels-Space...&sr=1-11&keywords=solar+panel+pool+heater#Ask
Combined with a solar cover on only 2ft deep pool - it should be enough to play around in, even if its just used as large paddling pool with slide attached etc.
