Hello
We have one of the above, a 3kw infrared heater that was quite expensive and I plan to take it away as we are moving house.
I see there are some cheaper ones out there c£100 that are of similar power.
Presumably the wiring is the same? Mine is fused to the fuse box and spur next to the heater.
Anyone used these makes?
Cheers
uk.trotec.com
castleheaters.co.uk
This is mine
Cheers
/en_GB/1410003215/Design-infrared-radiant-heater-IR-2200-144226-1648032353.jpg)
Design infrared radiant heater IR 2200
Design infrared radiant heater IR 2200Infrared heat (2,200 W) for the highest demands for wall and ceiling mounting - with remote control and 2 heating levels'
KMH-30R 3KW Infrared Wall Mounted Outdoor Garden Heater
Shop the KMH-30R 3KW Infrared Outdoor Heater. The remote control aspect of this 95cm heater means you will only have to get up to pour yourself another drink.
This is mine
Shadow XT Bluetooth 3kW & 4kW Remote ULG Patio Heater
The Shadow XT Bluetooth Heater from Heat Outdoors comes with bluetooth functions that allow you to choose up to 10 different heat outputs.
www.heat-outdoors.co.uk
