Outdoor light switch question
19 Oct 2011
Cheshire
Hi I have a fused spur set up already installed outside of my house for lighting (We moved in recently) but the lighting has never been installed... The fused spur is from a socket on my ground floor ring main.
Id like to run lighting from this via an outdoor switch.. the previous owner left us a single two way switch for this but Im thinking this is not suitable.
There will be a LNE from the fused spur in and a LNE from the switch to the appliance.
Which is the correct switch to use?
The fused spur is already in place & the lighting isn't really for security, its for everyday use & for when we use the garden for entertaining.
Thanks for the link but which is the exact switch I need??
1 way/ 2 way, single pole/ double pole???
Do you want to be rogered, sherly?
You certainly want something doing to you, to bring you to your senses (assuming you have any, which I doubt, given that you think someone in the USA should be spamming a Dutch website onto a UK forum)
One hopes that the outside FCU is IP rated.
You will need a dual pole switch.
Something like this will be needed.
http://www.thesitebox.com/greenbrook/ip44-weatherproof-outdoor-switch-double-pole-wnswdpc.aspx
