I am hoping to add 2 outdoor wall lights to light up my patio.
I have a double socket indoors next to the patio door, which is not a spur, so am planning to run a 1 metre length of 2.5mm cable from the back of the socket to a new fused switch on the wall above the socket. Then run some 1mm cable from the back of the fused switch to the 2 outdoor lights.
My questions are:
1) Re. The latest regulations, am I allowed to do this myself?
2) What is the best way to feed the cable from the socket to the fused switch? I have plaster board walls so am thinking that I will need to first make a hole in the plaster board for the new fused switch then drop the 2.5mm cable down to the socket in the wall cavity. If that's correct is it ok if this cable is not to attached to anything, i.e. batons, between the socket and switch?
3) Can I use interior 1mm lighting cable when running cable from the new switch to the lights outside? The lights will be attached to the outside wall about 2m above ground level. Total distance from the switch to the lights will be about 5m.
Many thanks.
My questions are:
Many thanks.
