Hello
I wish to have some outdoor wall lights installed in the near future and I'm just in the process of working out costs and seeing if it is feasible to do myself or if not approaching a few electricians for quotes.
I currently have external plug sockets in the back garden, they are the fully IP rated type that have the kind of cover that can be fully closed over an in-use plug. These sockets are fed from a spur from the downstairs ring which is protected via an RCD at the consumer unit.
As per opening paragraph, I now wish to install some wall lights on the back of my house and was hoping / thinking that the most feasible way would be to either do the following
1) Run a "spur" from the external plug sockets to a fused switch. The lights are wired up to this fused switch spur and the switch will naturally control the switching on / off of the wall lights. Is this feasible / compliant? Could I do it myself or is this classed as Part P work?
2) Wire the wall lights to a standard 3 pin plug (fused accordingly) and plug them into my sockets. The wall lights can then be switched on / off using the switch on my socket plate. Is this feasible / compliant? Could I do it myself or is this classed as Part P work?
Your advice would be greatly appreciated.
Thank you
Thank you
