Once the safety valve has opened (ie if the pressure gets to around 3 Bar) they have a habit of not resealing once the pressure drops. Since it doesn't re-seal the system pressure will then drop down to zero potentially damaging the boiler. Unfortunately the safety valve is located behind the boiler and is no 5 minute fix. I would imagine it's easier to take the boiler off the wall to replace the valve.
That's one good reason to disconnect the filling loop after re-presurising...they are not flexible for nothing.
Looking at the colour of the water the system appears to have suffered severe corrosion (unless the staining was from a previous system). For any hope of long term system reliability the system needs a good cleanout followed by a quality inbitor to prevent ccorrosion.
