Hi, wondered if anyone could help with an outside lighting problem?
I've run a 1.5 t&e from the fuse board (down stairs lights) to the first light outside, I've connected the brown to live and the other brown that gos to the next light to the natural, leaving the two blue cables together in a connector block, the cable then Goes to the next light where I've done the same, from here it goes to the switch where the brown goes to com and the blue to 1st way.
I can't under stand why when the light turns on by the switch the bulbs only glow and don't come on full.
If I disconnect the light nearest the board and just connect the cables back together then the light left comes on full power!!!
The bulbs are both 40w, max to be used is 60w.
Any ideas?
Any ideas?
