but, again, what has that got to do with the minimum CSA of cable in a 'power circuit'?
Very little but a lot to do with the distinctions between power and lighting circuits in the regulations.
Well, one of the problems with that Table (in its previous form) was that nowhere in the regs was there any explanation, let alone a definition of what those two circuits were, or what 'the distinction' between them was! The original BS7671:2018 added a note to that Table indicating that "lighting circuits" might also supply things like fans, but that's all!Very little but a lot to do with the distinctions between power and lighting circuits in the regulations.
my understanding way back in the 1960's was
Lighting circuits had only hard wired lights, no sockets to plug equipment into
Power circuits had only sockets for items that had to be plugged into. Nothing hard wired.
Plugging an electric iron into a bayonet lamp holder hanging from a ceiling rose was at odds with the rules
I never came across that, but maybe it depended on the area of the country.I also have vague recollections that in some houses power and lighting might have had separate meters with the cost of a kWh being more than the cost of a lighting kWh
Our 1951 council house had 5x 15A socket radial in 3 bedrooms, lounge & dining room. Upstairs lighting circuit with a 5A socket in kitchen and downstairs lighting circuit with a 5A socket in loungeI never came across a socket on a lighting circuit, apart from maybe an electric clock socket.
It is also off topic and something he should know anyway.Unfair question. It is the same colour as his unicorn.
The house in which I was 'brought up' had a number of 5A sockets on (5A) lighting circuits. The two or three 15A sockets were on 15A 'power' circuits. There were also sometimes things dangling from B22 adaptors (again, obviously, on 'lighting circuits').I never came across a socket on a lighting circuit, apart from maybe an electric clock socket.
Even back in the 30’s sockets could be found on lighting circuits. Usually a 2 or 5 amp 2 pin on the upstairs landing and a 2 pin 5 amp in the smallest bedroom. The other bedrooms and the reception rooms all had one 15amp socket on power circuits.my understanding way back in the 1960's was
What you believe is your choice. At my prievous house I fitted two outside sockets without isolators and never rain getting into them over 10 years. The secret is to install them properly with the appropriate silicon sealing. My present house which I've been in 18 months I inherited 2 outside sockets without isolators and they have been no problem.I believe every outside socket should be isolated inside the property with a double pole isolator. The British climate is wet, and rain getting into external electrics will cause nuisance RCD tripping at best. Also, your external socket could be used illicitly by anyone! What the eye don't see...........
I would say that your 'belief' corresponds with what most people would regard as desirable/sensible, for the reason you give - but there is certainly no regulatory 'requirement' for such an isolator.I believe every outside socket should be isolated inside the property with a double pole isolator. The British climate is wet, and rain getting into external electrics will cause nuisance RCD tripping at best.
One often hears that said. However, I'm intrigued to know what people think that others might plug into a socket on the outside wall of their house! I suppose it's a little different if the socket is in a distant part of the garden, or in/on a remote outhouse - but I still wonder what it is that people fear my get illicitly plugged into it!Also, your external socket could be used illicitly by anyone! What the eye don't see...........
Electric vehicle car charger on a shared driveway. ( when the owner of the socket is not at home )I'm intrigued to know what people think that others might plug into a socket on the outside wall of their house! I
That's a very specific (and 'modern') case. People were worrying about others stealing electricity from their outside sockets long before anyone knew what an EV charger was!Electric vehicle car charger on a shared driveway. ( when the owner of the socket is not at home )
Very similar here. In fact, I have more than five sockets, and more than two water taps, scattered around my garden. Like you, I can isolate them internally if I want to but, in the case of the electricity, have never felt the need to (other than during maintenance!).I have around five sockets scattered around my garden, plus two water taps. I can isolate them internally, but I have never felt the need in regards to theft.
