Hi everyone,
I came across the following wiring in a kitchen and the owner said that he doesn't want an electrician around before I fit the new kitchen as everything has always worked fine and I would like your opinion.
From cooker switch above worktop 6mm cable to cooker outlet plate.
From there hob is wired with 6mm cable and From the same cooker outlet plate there's a 2.5mm twin & earth cable going 4 inches down to a 13A rcd socket where the oven is plugged in with its original 13A plug.
It's this ok?
Also the rcd socket is cracked and the owner wants to change it to a standard one (I'm not touching it, he will do it himself) because he said the oven plug is fused.
I would appreciate your expert opinion.
It's this ok?
