oven/hob
20 Jun 2011
Nottingham
hi im planning to replace cooker /and ad electric hob i currently have single built in oven plugged in via 13amp fuse protected by 20amp cooker switch on its own radial circuit protected by 45 amp mcb and gas hob is plugged in for ignition question is i want to replace oven and have a electric hob instead of gas would this circuit cope or would the hob need its own circuit
A number of factors would have to be considered
What it is power rating (in watts) of the new hob?
What it is power rating (in watts) of the new oven?
What is cross sectional area of the cable supplying the hob and oven
How is the cable routed to the oven/hob - does it go through any insulation etc
Perhaps you should get an electricain in to quote you and make sure it will be safe.
