As the title really! It's be cheaper to run t&e internally, then junction where it leaves house before swa to garage.... Is this good practice, or should I stump up and run the swa right back to CU?
but if the run in the house is where 'ordinary' cable would require an RCD then you might prefer to use SWA and not have an RCD in the house for garage installation.
