Hi, wonder if anyone can help, I have an overheat on a Baxi Solo 3 PFL60 that won't clear.
The system has two heating circuits (upstairs and down) and one hot water.
This will probably be self caused but I seem unable to clear the problem.
Due to building work one of the rads needed changing to a larger one, having done this successfully on the upstairs circuit I followed the same process for down.
As the pipework needed extending a short distance I opened Honeywell silver valves by moving small latch to side and catching them.
Drained down the pipework, extended new pipe for new rad and fitted rad.
Re-filled system back to pressure releasing air from rads both up and down.
All hot/cold taps opened and run to ensure no splurting of air.
Ran hot water only which then tripped to overheat within minutes. After a while it would reset, tried downstairs heating circuit but nearly straight to overheat and wouldn't reset.
I had a look at boiler and to top right hand side is a pipe with a valve similar to a rad on top, I opened this and let air out.
Still could not reset boiler from overheat.
Water pressure in system is between 1 and 2 as per normal.
Red lock valves are open(screwed out).
I've read quite a lot of posts but haven't found something similar to this other than several overheat type issues.
Any advice on where I've gone wrong and what I should do to fix the problem ?
