You should also replace all the sockets that have overheated.
Not only cheap sockets.Cheap sockets can fail at the switch, it does not 'make' correctly causing overheating.Bought 10 pack from Wickes once and had to replace 6 of them when switches failed.
I would clean the dryer plug pins with a kitchen scourer or that liquid that gets metal shiny.
(maybe some pics of it? etc)
Also remove the fuse cover and pic inside
When you talk about 'failing', are you just referring to the neons?When we refitted/rewired our kitchen I decided to install sockets with neons and purchased 10 MK DSSO's, in the end there we only installed 6. One was faulty out of the box leaving 3 spare, as they failed the spares were used up then non neon sockets used. 11 years on we have only 2 still in place and a neon in one of those has failed. Or in other words 90% failure rate.
No, no, no.When you talk about 'failing', are you just referring to the neons?
Neons in accessories do 'fail' (at least, start flickering') quite early, which is one reason why I've virtually never used sockets with them. However, in terms of the sockets themselves, I have lived with countless of them (many/most of them being 'cheapos') for decades (I would guess there are at least 100 in my present house, where I've been for ~35 years) and I don't recall ever having to replace one because of 'failure' (the very rare replacements having been occasioned by mechanical damage).
Kind Regards, John
That sounds about par for the course over a significant period of time.So I think it's highly likely the failure rate for the neons is 17/20 or 85% as there are only 2 of the original DSSO's and one with failed neon.
What sort of 'failure' are you talking about? As I said, even just thinking of my present house, I've lived with probably ~100 sockets for ~35 years without being able to recall any 'failure' (other than due to not-electrically-related mechanical damage).Equally failure rate of the sockets is 8/10 or 80%.
Interesting. AsI said, with all the sockets I've 'lived with' for decades,I don't recall ever have experienced any of that.These MK's have stopped working in a variety of ways, I don't recall every detail but several of the DP switches went open circuit, a neutral link bar rivet not tight, a live receptical or two broke up, a couple of sockets or may have been 3 jammed preventing plugs being inserted ...
Quite. A lot of people seem still to believe that 'most expensive must be best' but, as I said, the great majority of those I have lived with, without troubles, for decades were 'cheapo' ones - probably, like yours, Homebase - or possibly, in some cases, Texas, which is what our local Homebase was prior to becoming Homebase (and then, much more recently, briefly becoming Bunnings, then back to Homebase againThe most annoying part of it was I really thought I'd do the right thing in the kitchen, DP switches, lights and a decent brand. I don't recall the cost but I suspect closse to a ton. The £2 replacements have been perfect.
My favourites have always been and always will be 'Bill'.Interesting. AsI said, with all the sockets I've 'lived with' for decades,I don't recall ever have experienced any of that.
Quite. A lot of people seem still to believe that 'most expensive must be best' but, as I said, the great majority of those I have lived with, without troubles, for decades were 'cheapo' ones - probably, like yours, Homebase - or possibly, in some cases, Texas, which is what our local Homebase was prior to becoming Homebase (and then, much more recently, briefly becoming Bunnings, then back to Homebase again).
Kind Regards, John
