hi, have a problem with a glowworm energy saver condensing boiler on a y plan system,the problem is the boiler runs ok for 30 mins or so water and heating gets up to temp then the boiler starts making a banging noise and cuts out,to get it going again it needs to be reset by the red stat under the boiler.
The pump is running and upstairs and downstairs rads heat.hot water is fine.
can anyone suggest what could be causing it?
could the pump be running to slow even tho it is set on 3?
thanks
thanks
