Overide switches
Sorry guys forgot this
The outside lights will be on a seperate breaker from the new box being fitted and the lounge switch will be from the existing downstairs lighting circuit. Got too caught up in trying to keep it all neat I forgot this
Thanks again for the help :)
Have your electrician put a DP isolator next to the CU for the outside light circuit, then you'll be OK with a regular 3G light switch in the lounge.
Or have the lights on an RCBO, then if they do trip, they only trip themselves.
No actual requirement for a double pole switch though, AFAIK.
So water getting into an outside light can never generate a NE fault?
:confused:
I'm not disputing that, and I think it's a good idea.
My comment is that, as far as I know, it's not compulsory to have a double pole switch.
I only mention this as fitting a double pole switch could prove difficult for the op who appears to be trying to make a neat job without fitting loads of switches and making too much work.
If you take this path you need to be careful.
The switch will need both circuits to be turned off to properly isolate it.
Its worth putting a note in the switch box and on the consumer unit to make future users/sparks aware of this.
Ok, double pole isolator or rcbo, got that, then use a normal 3g light switch.
The new box will be bang up to date so ill let the spark know this is required :) not saying that he wouldnt but best to mention it
