Overload
14 Mar 2005
I intend using a multi socket to plug my TV, DVD, Surround sound system, games console and amplifier into 1 plug socket. Would this overload the socket?
Thanks.
Paul
I'd have thought it unlikely (recall you can plug a 3kW electric fire in there) but you need to check the labels and see what the total load is, to know for sure.
But woudn't you be much better of using a fused trailing socket ? The fuse would ensure you didn't overload the socket.
13A at 230v = 2990W.
I would use a 6 way trailing socket, preferably with switches so if you want you can switch individual items off.
I think these trailing sockets are great for low power items such as AV stuff, but not for anything meaty.
I live in a housing executive house with extremely substandard wiring which when i first discovered i immediately purchased more smoke alarms but through a 1 gang 13amp socket which is spurred off a ring i have my computer,moniter,sound system,28"tv,video,xbox,ps2,beer fridge and desk light through 3, 4 gang trailing leads and have not had any problems in over 2 years.
Thanks.
Paul
check out the input power requirements of the surround sound system and the amplifier theese could be non-trivial. other than that i doubt you will find any problems.
power requirements are usually marked on a sticker on the back of equipment. in any case the plug fuse in the extention lead should blow before any damage is done.
