which is better? paint pads... or rollers?
do you get as much splashing with a pad that you do with a roller?
Old enough to have used Peter paint pads when they were first invented!..Its these modern versions I was thinking of , theyre pretty useless
....btw..Just how old are you Richard ?
I’ve found rollers bad enough on walls let alone ceilings; not too important if decorating a new build or completely stripped out room but when re-decorating a furnished room you have to cover literally everything in sight. Have you tried a decent 5” brush on the ceiling? I prefer shorter bristled brushes rather then the longer ones supposedly designed for emulsion, they seem a bit unwieldy to me & you can’t really cut in with them; don’t seem to work as well to me.I was thinking more for the ceiling..
with a roller I seem to get spray off it and drips everywhere.. normally all over me..
I was hoping that a pad wouldn't drip as much..
Thin a bit less than mist coat; start at around 10% & try it but only add just enough water so the pad glides & doesn’t drag. Difficult to explain but if you try it you should know what I mean; it very much depends on the paint. The trick with pads is no to overload them, once paint saturates the sponge backing they will drip & splash just as much.you say it needs thinning? how much?
same as a mist coat?
Out of interest, what roller sleeve would you recommend, if there is one that works as well as that I’d like to give one a try?Using a good quality roller sleeve & good quality trade emulsion will give a nice uniform/even & superior finish to brush on a ceiling anyday
No question that a roller is quicker than a brush & if the main concern is time on contract work then fine. I think Coljack may be more interested in getting a good finish whilst not ending up looking as if he’s contracted a serious disease at the end of it rather than getting it done in the shortest possible time. Using a brush is slower but, in reality, it won’t take that much longer when you take account of “cutting in” around the room. I could easily do a 12 x 12 ceiling, 3 coats in a morning with a large brush & if I could find a decent, large pad as good as the originals, it would beat a roller every time.not to mention the time factor (though I shall) I know I can cover an average 12' x 12' living-room ceiling with 3 coats in a morning by roller, if I used a brush it'd take me so long I'd be at it all day - Id never earn money or for that matter even get the contract !
Perhaps LJW61 is too young to remember them but the original “Peter” paint pads produced many years ago had a mohair head & when used with slightly thinned paint were very good indeed. Faster to use & more accurate than a roller, no mess, splashes or drips as long as you got the mix right; none of that ripple build up that starts to look like mild Artex after a decorating a few times with rollers & in fact a better finish than you’d get with a brush.
I used nothing but pads for many years but the ones generally available now are nothing like the originals. The mohair pad has gone to be replaced by modern synthetics & is nowhere near as dense to the point where they no longer work at all well. Despite trying several different makes over the last few years none are a patch on the original design. I still don’t like rollers very much but use them occasionally, I prefer a large brush.
