There are 2 sides to the resin tube, and they mix in the tube as you press it out, so the tubes useless once you use it and can't be reused. So you need to be prepared to do all the filling in one go. Yes, it's soft and squidgy as you pump it in, and then it'll start to harden, so if you want to rub it down, you've got to do it before it goes really solid. Hoover, wet, let dry, and then fill. And best of luck.
