Painting MDF
So ive just made a fatal error, ive painted the water based gloss straight onto the sanded mdf (mostly got paint on but the edges are bare)
Whats the worst that could happen? Am i going to need to resand and start again?
You've lost me now. Are you talking about the bathroom or what the decorator 'was' going to do? :confused:
If the bathroom, it's probably going to be ok because the gloss is water based - oil based would just soak into the MDF and fail to cover. It won't have given you as good a finish as priming the bare MDF but will probably adhere well enough not to cause too much of an issue.
The bathroom which is what im doing.
So can i give the gloss another coat tommorow without sanding it as i think if i sand it, it will all just peel off? Im using one coat gloss but obviously as i forgot to prime it needs another coat.
Ive asked the decorator to do the other glossing with a water based gloss and therefore to sand it down prior to application, he is ok to do this but isent planning to use a primer as it wont be down to bare wood, will this still provide a good enough finish?
