i recently had to check for a leak in my central heating system by marking the water level in the f & e tank with some tape and then holding ball cock up to see if water dropped.
To cut a long story short, recently had to remove two radiators and then re fit them, during the refill the piece of tape (I forgot to remove it) dislodged and has ended up somewhere in the central heating system.
Should I be worried? It was about 6 inch strip of masking tape
