Part P certificates
7 Jul 2006
With all the new regulations relating to the part P legislation electricians must be making a killing!! All I read is that if I do a certain job myself I have to get it certified, but how much do electricians actually charge to come out and inspect, say a new ceiling rose and issue a certificate??
impossible to say, depends on several factors.
who's the electrician? , what part of the country? whats the extent of the work?
not just as simple as that either. many electricians are very wary (and rightly so) about signing off other people's work. especially if they only have the DIY'ers word that they've routed the cables correctly or have jointed the cable suitably.
you've got to remember that the electrician might not be able to see all of the circuit.
me personally, i wouldnt sign off on anything unless (a) id done it or (b) i was 100 percent sure the circuit was up to standard.
Not quite the way it works.
Some DIY jobs you have to notify to your council in advance, and pay them a fee. For that fee they are supposed to carry out whatever inspections they want, and then they issue you with a Building Regulations completion certificate.
No electrician that you employ can certify your work as being compliant with the Building Regulations.
ok , but what if the work was not notifiable and was say the installation of a new downlight in place of a ceiling rose (with all the wiring visable). Are we talking 20, 40, 100 quid for example in the london area?
The installation of a downlight inplace of a ceiling rose is notifiable.
As has already been said, it is unlikely you will find an electrician who will sign off someone elses work.
The only real option would be to get a periodic inspection report carried out on the installation.
I was informed that it was only if it was in a bathroom or kitchen???
Nope. Downlighters anywhere becuase of the risk of badly fitted downlighters setting fire to joists ETC, and also to ensure fire rated downlighters have been fitted where apropriate.
Following posts on this thread, I have contacted my local(east herts) buildings control department, and have been informed that this work is NOT notifiable.
How are us Diyers meant to understand this law if the pro's give differing answers.
They are wrong.
This is the latest version of Approved document P
Approved document P said:
Special installations: Extra-low voltage lighting installations, other than pre-assembled, CE-marked lighting sets
Special installations are notifiable work.
You're making that up.
RF Lighting said:
They are wrong.
No they are not - you are.
1) Before you get to that section of Schedule 2B the work qualifies as exempt via [code:1]1. Work consisting of -
(a) replacing any fixed electrical equipment which does
not include the provision of—
(i) any new fixed cabling; or
(ii) a consumer unit; [/code:1]
2) You don't know if these are ELV downlighters or not, and if they are, what are the chances of them not being CE marked?
I can confirm that they are pre assenbled low voltage, and CE marked.
When you say pre-assembled, do you mean that they provide wiring connectors, fittings and transformers all ready to connect up with no wiring other than the connection to the mains input?
yes, all that is required is to clip the connections for the lights together, and attach the transformer via a pre attached connection block to a t & eath attached to the existing ceiling ceiling rose connection(which obviously has to be changed to a junction box)
