Hi
Was at work today pondering over some work i am having done, and cam eup with a question i want to ask you. Please dont take this the wrong way, i am not picking fault with Part P or current regs, i will always strive to do things the right way and i also believe in using good tradesman where possible.
BUT, as i understand it, if i have a double socket on a ring main in my dining room, i, as the home owner and someone who is familiar with simple electrical proceedures, could spur off that with 2.5mm T&E, in some 25x16 trunking along the wall (not that i would because of asthetics), and install another socket in the opposite corner of the room? Yes?
However, on the other side of that wall, literally one bricks depth, is my garden. I, as the home owner, couldn't drill through that wall and install a weather proof socket there instead of the internal one described above? That is contravening Part P etc.
What is the difference between these 2 scenarios that i am missing? If it really is the case, would it not be better for all electrical work, from replacing a socket anywhere in the house to running a spur etc, to be covered by Part P and requiring a fully qualified electrician?
I really am not trying to start a row here, or buck against the law, i am genuinely interested in why the change as described above? Or am i totally wrong and not even the house holder can spur inside his house now? Perhaps my thoughts are outdated?
