hello.
i would like a few things clarifying and some advice.
whos responsibility is the part wall act?
building regs approval has been obtained. this was done through an agent who sorted out plans, structural engineer and building control.
Is it the homeowners, the builders, the "agent", the structural engineer, or building controls responsibility to tell the homeowner about the party wall act, and who should create the letter and deal with it?
there are 2 issues that i think the party wall act might be needed for.
1st
an external single story wall is being made higher by adding on around 5 courses of brick work. this is the type in "diagram 2" on this link to the pdf.
http://www.planningportal.gov.uk/uploads/br/BR_partywall_explain_booklet.pdf
its a single story full height wall used as a conservatory wall. both sides have their own wall which is 2 bricks thick each but the walls are touching.
does this need a party wall act giving to next door?
what till happen the work is just done quickly and party wall act ignored?
2nd.
inside the property, where the original external house wall is, its being removed and 2 UB/RSJs put in. One side sits on an existing pier/pillar but the other end sits on the party wall of the other house on the other side of the house.
As the beam is going into the party wall then i think a party wall act is needed. Should a party wall act be make up? what will happen if the work is just done quickly and no party wall act done?
this is two different neighbors and so 2 different cases.
so id like to know if 2 party wall acts should be drawn up and generally who would be responsible for this?
1st
2nd.
