Im looking for some technical advice on the paslode im350 if possible.
Ive done a complete service on my paslode gun including striping down and servicing the piston and cylinder cleaning all the waste discharge from the gas build up. replaced ring seal checked that the motor spins and the spark ignite each time i compress and release microswitch without cylinder/chamber cover on as show by paslode rep.
lubricated all moving parts and been carefull not to saturate.
i really dont understand. it miss fires allmost perfect every second time bar now and then. I heard comments that the gas chamber miss not be filling up quickly enough which does sound feasible.
I heard also that if the gas has been kepted in cool conditons this could created the same double miss fire problems. Well ive tried both of these leaving gas in room temperature for several hours before re-testing and still have the same problem.
for others that may think i have used a different cartridge thats out of date no, the gas is paslode and in date to jan 09 and when test im not using nails so its not jammed. Yes the battery are good and charged.
So sorry for the long winded explanation but wanted to make it clear that ive tried most things to cancel out wasting people time.
Thank you for any help
