J
Johnmelad502
<edit> just seen your post above. How do you do an insulation test with a clamp meter and multi meter?
That is not a requirement of Portable Appliance Testing.
Have a read of the IEE code of practice for inservice inspection and testing.
I cannot believe some of the stuff your coming out with, if it was 1st April I would have taken this as a wind up!!!
It very much is, I'm afraid.
I assume that with your clamp meter, you are doing some sort of leakage test? Well, the leakage test (or protective conductor/touch current measurement, as it's called nowdays) is additional or complimentary to the insulation test, and should only take the place of it if the appliance may be damaged by the insulation test, or give suspect readings.
As JBPElectrics suggests, get hold of a copy of the IEE Code of Practice (3rd ed.), and have a good read, as it looks like you're making some of this stuff (not all mind!) up as you go along.
I think you are getting confused between PAT and Periodic testing. Not the same thing at all.
Nope, no confusion on my part. I know exactly what I'm talking about.
Been doing PAT for long enough!
Have a read of the IEE CoP and it will all become clear to you...
If the Health and Safety Executive disagreed with you, would you still believe that a Code of Practise was better informed?
Do you have a link to the h&s document please?
http://www.hse.gov.uk/pubns/indg236.pdf
http://www.hse.gov.uk/pubns/indg237.pdf[/QUOTE]
I still don't understand. If you don't carry out the necessary tests, how can you be offering a Portable Appliance Testing service? Granted though, I am surprised by the contents of INDG237.
