I'd do a visual, load and possibly even an insulation test for a class 3.
Why would you think that a mains powered phone charger is a Class III appliance?
Do you know what Class III means?
Perhaps, but then a gang of foxes might storm the pub, a car might crash through the window, frozen waste products might be ejected from an overhead aeroplane.
That's all very true, but do you believe that "PATesting" would weed out a significant proportion of chargers that were liable to disintegrate/ melt/ explode etc.?Given the widespread availability of fake chargers for phones and other i-gadgets, which have a habit of disintegrating / melting / exploding, it seems to me that chargers are rather higher risk than granny's one-bar electric fire.
Had the charger disintegrated leaving the exposed live pin in the socket, the pub would have had to turn off the circuit (and we don't know what else is on that circuit - beer pump or pie warmer etc - causing loss of trade) and call a sparky to get the pin out of the socket.
Afaict there are two meaningful tests you can do on such a device with a normal PAT tester.Is it even possible to PAT test double insulated items with no earth?
Not required. Low risk environment, visual is all that is required.
How do you determine the environment of someone's personal phone charger that they use at home, down the pub, in the swimming pool?
How do you know it isn't a lethal fake import with mains at the output terminals?
Phone blows up first time its used?How do you know it isn't a lethal fake import with mains at the output terminals?
Home = low risk environment, no need to PAT
Pub = low risk environment, requires visual inspection only.
Swimming pool should not have PA's in them.
Checking for cheap/fake imports is not part of the PAT in low risk environments.
Does PAT equipment recognise counterfit fuses in a plug?
