Hi
I’m starting my patio project at the moment, and I’ve come to a bit of a dilemma regarding drainage.
There is currently no paved area in the back garden - just grass/soil/mess, which all slopes down toward the house. The land is currently roughly level with the DPC with a bit of a trench around the house/garage.
The garage wraps around the back right corner of the house and there is a pathway down the left hand side which has a surface water drain running underneath it. The gutter from the garage roof runs to a down pipe on each of the rear corners into a gulley and then underground via 110mm pipe to the drain under the pathway.
My plan was to build a patio parallel with the back of the house, protruding level with the back of the garage to start with, and then at some point (maybe next year) extend the patio behind the garage right into the back right corner of the garden.
The dilemma is what to do about the drainage. I was thinking of removing the gulleys and underground pipe, and fitting an Aco/linear drain at least 75mm below DPC all around the back of the garage and house to join the drain under the path.
Am I right in thinking that I need at least 1:60 fall for drainage? The distance around the back of the garage and house is about 13m, which means a difference in height from the furthest downpipe to the path is going to be about 220mm (roughly 3 bricks).
Surely that can’t be right?
1. It would look daft
2. The end of the linear drain would be lower than the joint to the drain under the path!
Any thoughts, please?
Sorry about the essay!!
