pcb fitting
I would like to know that one as well ??
So gas to air what combustion settings are altered when a SOLO board is changed
When a CORGI attends a boiler and does "work", including changing a PCB, he has to check the burner pressure and ensure the flue is safe and the boiler can be left working for the user.
Merely changing the PCB does not involve any resetting. There are no adjustments on it.
Tony
Indeed namsag, i meant elec tests before and after, the BP and FGA too, if working. If we point out that the Solo has no control over modulation or fan speed then the OP may want to fit it. OOPs. Personally i wouldn't want a DIY to change a PCB on any boiler never mind a Solo.
