peak time
25 Jan 2009
Aberdeen
I have two storage heaters which come on about 11pm at night and go off at 7am. I got a new replacement immersion heater installed, as the timer was not working, an Economy 7. I noticed this morning my immersion didn't go off till 8am. Is this hour being used as the expensive time? Please can someone answer my query?
Depends how your timer is set and whether we are on british Summer time or winter time.
Low rate tariffs keep changing "to meet the lowest demand hours"
Most people will store heating/hotwater partially at low rate, partially at high rate.
Contact your supplier (the one that sends you the bill) regularly to find out current high/low hours.
And do it in writing, chances are that the dumb broad in the call centre in india doesn't actually know much more than you do.
While this MAY/COULD be true of supplies on a teleswitch, it is NOT true of supplies on a timer.
@ perfect, your E7 immersion heater should be wired so that it only recieves power during off peak hours. Easiest way to do this is to wire it to the storage heater board, which comes live at off peak. It all depends how your system is wired. Do you have two immersions in the cylinder?
How does the timer keep time during on peak hours if it is wired to the off peak DB
How will you boost during on peak hours
Checked on the moneysavingexpert website, and it seems that it changes from region to region, and what type of tariff you are on.
Is you immersion heater supplied through a "Horstman" timer (time clock with boost facility)?? if so it could be just set up incorrectly!
