Yes, it depends on which side of the matter - installer or user - the common sense should be.
True, but many regulations appear to be based on consideration of the fact that users may not exercise (or may to be able to exercise) an ideal amount of common sense. Indeed, if one were going to rely heavily on user common sense, one could perhaps argue that there is no need for bathroom Zones (or for the restriction in relation to sockets in bathrooms) at all.Yes, it depends on which side of the matter - installer or user - the common sense should be.
That, indeed, is a 'converse' point (and another would be that the zones might extend all the way up to, and including, the ceiling). However, as I said, if one was going to rely heavily on 'user common sense', one probably would not have 'zones' at all.Or, conversely, that the zones should not end just 600mm. from the bath.
Quite so. Many of our electrical regs do seem to be designed to address incredibly small risks ... risks far smaller than those which exist (and generally are 'accepted') in relation to many other aspects of life.As for sockets - and Europe, there apparently is no need for the restriction. Not dropping like flies here.
So because a risk is small, you are suggesting there is no need to reduce it further?Many of our electrical regs do seem to be designed to address incredibly small risks
Agreed, but what about inadvertently splashing water on a socket-outlet close to a bath?It depends whether you consider sticking your finger in a lamp-holder while having a bath a "risk".
It's equally not an "accident".
We've been over that ground many times before before. In the real world, there is (IMO) a limit to how far one can/should sensibly go in reducing risks which are already extremely small, particularly when there are far greater risks which would be more usefully addressed within the context of available resources.So because a risk is small, you are suggesting there is no need to reduce it further?
If that happened, how likely do you really think it is that any harm would come to anyone?Agreed, but what about inadvertently splashing water on a socket-outlet close to a bath?
That could well be part of it.I do think the regulations (not just electrical) in Britain are getting to the stage of thinking up new things for job preservation.
who(m?) was saved.
