rf i understand were you are coming from but i think my question was reasonable the other lads comments straight forward. (not making people look small)
There are so so so many people out there carrying out periodic inspection reports who simply do not have a clue what they are doing.
I'm not against it. Far from it.Question for dingbat....
I've noticed on a few occasions, you seem to be against direct measurement of Zs on final circuits? is this just a personal bias? or are there moves on the college scene to try and do away with it in the mainstream in the name of H+S for students?
When I was at college I was taught it was the prefered method to obtain the Zs, and that if you calculated it that it should be noted on the certification along with the justification, although I can see the reasoning behind what you suggest, even more now that we are working under the 17th and have to fit an RCD to anything that stays still long enough , my loop tester does a reasonably accurate 2 lead loop test on non trip mode most of the time (but the results are still not perfect!), but trying to do it with some of the other testers out there can be a nightmare!For some years now, the direct measurement of Zs has been discouraged for initial verification, simply because it is not necessary and thus would contravene regulation 14 of the EAWR 1989.
Spot on, the point I was going to make was that for a anything bigger than a simple domestic property, it would be somewhat difficult to do if one was to declare direct measurement on a live circuit as forbiddem!However, for a periodic inspection of an installation it may be the most effective way of determining the only test requirement for periodic inspection as laid down in BS 7671.
What I most strenuously discourage, though, is the unthinking live working carried out by persons insufficiently competent to understand the implications of their actions.
