So they can only consider the impact on my one adjoining neighbour then? They can't wander off into the fields and say it's not in keeping with the greenbelt when you look at it from a distance?
You seem to imply that the LPA has a say (on amenity) even if they get no complaints, but that's not so; your screen shot from the guidance confirms this.The LPA does consider the effect on the amenity of the neighbours irrespective of whether they get any complaints or not. It's in the guidance.
That then reverts back to my original interpretation of the rules that the LPA only get involved if the neighbours object and then should only consider it from the neighbours amenity.
The bit you highlighted only applies if the LPA receives a complaint.; if the LPA receives no complaint, they do not look at the scheme.
Your interpretation would suggest that this is almost akin to a planning application, which is not the purpose of the prior notification scheme.
No. Users of a field are not your neighbours.Users of a field can be your neighbours too.
