I still don't really know for sure exactly what the OP has done already and is planning on doing in the future!
I'm now also thinking about doing a second floor rear extension (ie above a single storey part of the house) under PD. Now if I were to do this first I would obviously increase the roof volume as a result of this extension.
Would this increase be then subtracted from the 50m3 I would be allowed for the loft conversion. Or could I carry on and make a loft conversion of the full 50m3 despite the fact that I've done the 2nd floor extension?
Planning permission is not normally required. However, permission is required where you extend or alter the roof space and it exceeds specified limits and conditions.
Under new regulations that came into effect from 1 October 2008 a loft conversion for your house is considered to be permitted development, not requiring an application for planning permission, subject to the following limits and conditions:
• A volume allowance of 40 cubic metres additional roof space for terraced houses*
• A volume allowance of 50 cubic metres additional roof space for detached and semi-detached houses*• No extension beyond the plane of the existing roof slope of the principal elevation that fronts the highway
• No extension to be higher than the highest part of the roof
• Materials to be similar in appearance to the existing house
• No verandas, balconies or raised platforms
• Side-facing windows to be obscure-glazed; any opening to be 1.7m above the floor
• Roof extensions not to be permitted development in designated areas**
• Roof extensions, apart from hip to gable ones, to be set back, as far as practicable, at least 20cm from the eaves
1) Do a loft conversion which will increase the roof space by 48m3 (ie less than 50m3) Under PD
2) Then immediately after do a first floor extension. This would have a pitched roof which has an additional volume of 20m3. Again under PD
Sorry I've been away from this site for a little while.
I've gone to my architect to discuss my plans. He seems to think we can do both things and they aren't related. What I mean by this is
Has he got it wrong?
Thanks [/b]
