- Joined
- 23 Sep 2010
- Messages
- 2,203
- Reaction score
- 484
- Country
Thanks for that last post , food for thought.
It does have a camshaft sensor , aswell as non standard cams.
The second lamda sensor has been connected and screwed into what looks like a made for the job enclosed tube, this has been cable tied to the brake pipes and has been work ok for some time , not sure how the ECU works out the fueling though , as sensor one is connected before the cat and sensor 2 should be connected after the cat !?
Will try the disconnect sensor - test - reconnect - test idea. But I dont understand why it runs if I allow fuel into the manifold , surely this proves plugs, camshaft and crank sensor ok ?
Even tried putting a earth and live to pump , not sure which the immobiliser cuts -off.
I'am almost sure something is telling ECU theres a prob , and it's immobilising it , could be a loose cable , bad con , anything. But will try the test - disconnect idea later.
The batt has been off all night , will try that before I go out this morn !
Keep the ideas coming please.
ALL sorted now , thanks , please dont ask what we did , as we have no idea !
For the life of me I cannot understand people not sharing the solution to a problem on the forum after the repair. I thought that was the whole point to a forum?
